orange pi a rtc DS3231
Napsal: 08 bře 2020, 11:48
Ahoj, nemáte zkušenost jak rozchodit na OrangePi zero modul rtc s DS3231? armbian
D
C
nc
- našel jsem nějaký návod zde, ale nevím jestli stačí změnit použité piny a jak tu synchronizaci spouštět automaticky po zapnutí:
https://forum.armbian.com/topic/7349-rt ... retch-414/
a ještě návod tady:
https://itcooky.com/?p=4023
označení pinů:+
D
C
nc
i2c DS3231N Clock:
apt install i2c-tools
armbian-config: activate I2C-0
i2cdetect -y 0
(modprobe) rtc-ds1307 ==> /etc/modules
root@nanopi-core2(192.168.6.21):~# more /etc/modules
g_serial
rtc-ds1307
in /etc/rc.local:
echo ds1307 0x68 > /sys/class/i2c-adapter/i2c-0/new_device
hwclock -s
Once correct you can write the system date and time to the RTC module using :
sudo hwclock -w
You should be able to read the date and time back from the RTC using :
sudo date; hwclock -r
compare hwclock
sudo hwclock -c
NeoCore2 Mini Shield:
Number# Name Number# Name
1 SYS_3.3V 2 VDD_5V
3 I2C0_SDA / GPIOA12 4 VDD_5V
5 I2C0_SCL / GPIOA11 6 GND
https://www.raspberrypi-spy.co.uk/2015/05/adding-a-ds3231-real-time-clock-to-the-raspberry-pi/
https://manpages.debian.org/stretch/manpages-de/hwclock.8.de.html
https://www.youtube.com/watch?v=ND2shVqV9s4
echo "Updating time via ntp from ptbtime3.pt.de"
ntpdate -q ptbtime3.ptb.de
echo "writing actual time to hwclock..."
hwclock -w
echo "reading actual time from hwclock..."
date; hwclock -r
