Arduino monitor VGA
morlor
Arduino monitor VGA
Příspěvek od morlor »
potřebuji spojit dvě proměnné a zobrazit na monitoru VGA.
tak to funguje static const char str0[] PROGMEM="NAMERENA HODNOTA";
ale tohle ne
int d = analogRead(1);
// static const char str0[] PROGMEM="NAMERENA HODNOTA " + String(d);
#include <VGAX.h>
// https://github.com/smaffer/vgax
#define FNT_UFONT_HEIGHT 6
#define FNT_UFONT_SYMBOLS_COUNT 95
//data size=570 bytes
const unsigned char fnt_ufont_data[FNT_UFONT_SYMBOLS_COUNT][1+FNT_UFONT_HEIGHT] PROGMEM={
{ 1, 128, 128, 128,   0, 128,   0, }, //glyph '!' code=0
{ 3, 160, 160,   0,   0,   0,   0, }, //glyph '"' code=1
{ 5,  80, 248,  80, 248,  80,   0, }, //glyph '#' code=2
{ 5, 120, 160, 112,  40, 240,   0, }, //glyph '$' code=3
{ 5, 136,  16,  32,  64, 136,   0, }, //glyph '%' code=4
{ 5,  96, 144, 104, 144, 104,   0, }, //glyph '&' code=5
{ 2, 128,  64,   0,   0,   0,   0, }, //glyph ''' code=6
{ 2,  64, 128, 128, 128,  64,   0, }, //glyph '(' code=7
{ 2, 128,  64,  64,  64, 128,   0, }, //glyph ')' code=8
{ 3,   0, 160,  64, 160,   0,   0, }, //glyph '*' code=9
{ 3,   0,  64, 224,  64,   0,   0, }, //glyph '+' code=10
{ 2,   0,   0,   0,   0, 128,  64, }, //glyph ',' code=11
{ 3,   0,   0, 224,   0,   0,   0, }, //glyph '-' code=12
{ 1,   0,   0,   0,   0, 128,   0, }, //glyph '.' code=13
{ 5,   8,  16,  32,  64, 128,   0, }, //glyph '/' code=14
{ 4,  96, 144, 144, 144,  96,   0, }, //glyph '0' code=15
{ 3,  64, 192,  64,  64, 224,   0, }, //glyph '1' code=16
{ 4, 224,  16,  96, 128, 240,   0, }, //glyph '2' code=17
{ 4, 224,  16,  96,  16, 224,   0, }, //glyph '3' code=18
{ 4, 144, 144, 240,  16,  16,   0, }, //glyph '4' code=19
{ 4, 240, 128, 224,  16, 224,   0, }, //glyph '5' code=20
{ 4,  96, 128, 224, 144,  96,   0, }, //glyph '6' code=21
{ 4, 240,  16,  32,  64,  64,   0, }, //glyph '7' code=22
{ 4,  96, 144,  96, 144,  96,   0, }, //glyph '8' code=23
{ 4,  96, 144, 112,  16,  96,   0, }, //glyph '9' code=24
{ 1,   0, 128,   0, 128,   0,   0, }, //glyph ':' code=25
{ 2,   0, 128,   0,   0, 128,  64, }, //glyph ';' code=26
{ 3,  32,  64, 128,  64,  32,   0, }, //glyph '<' code=27
{ 3,   0, 224,   0, 224,   0,   0, }, //glyph '=' code=28
{ 3, 128,  64,  32,  64, 128,   0, }, //glyph '>' code=29
{ 4, 224,  16,  96,   0,  64,   0, }, //glyph '?' code=30
{ 4,  96, 144, 176, 128, 112,   0, }, //glyph '@' code=31
{ 4,  96, 144, 240, 144, 144,   0, }, //glyph 'A' code=32
{ 4, 224, 144, 224, 144, 224,   0, }, //glyph 'B' code=33
{ 4, 112, 128, 128, 128, 112,   0, }, //glyph 'C' code=34
{ 4, 224, 144, 144, 144, 224,   0, }, //glyph 'D' code=35
{ 4, 240, 128, 224, 128, 240,   0, }, //glyph 'E' code=36
{ 4, 240, 128, 224, 128, 128,   0, }, //glyph 'F' code=37
{ 4, 112, 128, 176, 144, 112,   0, }, //glyph 'G' code=38
{ 4, 144, 144, 240, 144, 144,   0, }, //glyph 'H' code=39
{ 3, 224,  64,  64,  64, 224,   0, }, //glyph 'I' code=40
{ 4, 240,  16,  16, 144,  96,   0, }, //glyph 'J' code=41
{ 4, 144, 160, 192, 160, 144,   0, }, //glyph 'K' code=42
{ 4, 128, 128, 128, 128, 240,   0, }, //glyph 'L' code=43
{ 5, 136, 216, 168, 136, 136,   0, }, //glyph 'M' code=44
{ 4, 144, 208, 176, 144, 144,   0, }, //glyph 'N' code=45
{ 4,  96, 144, 144, 144,  96,   0, }, //glyph 'O' code=46
{ 4, 224, 144, 224, 128, 128,   0, }, //glyph 'P' code=47
{ 4,  96, 144, 144, 144,  96,  16, }, //glyph 'Q' code=48
{ 4, 224, 144, 224, 160, 144,   0, }, //glyph 'R' code=49
{ 4, 112, 128,  96,  16, 224,   0, }, //glyph 'S' code=50
{ 3, 224,  64,  64,  64,  64,   0, }, //glyph 'T' code=51
{ 4, 144, 144, 144, 144,  96,   0, }, //glyph 'U' code=52
{ 3, 160, 160, 160, 160,  64,   0, }, //glyph 'V' code=53
{ 5, 136, 168, 168, 168,  80,   0, }, //glyph 'W' code=54
{ 4, 144, 144,  96, 144, 144,   0, }, //glyph 'X' code=55
{ 3, 160, 160,  64,  64,  64,   0, }, //glyph 'Y' code=56
{ 4, 240,  16,  96, 128, 240,   0, }, //glyph 'Z' code=57
{ 2, 192, 128, 128, 128, 192,   0, }, //glyph '[' code=58
{ 5, 128,  64,  32,  16,   8,   0, }, //glyph '\' code=59
{ 2, 192,  64,  64,  64, 192,   0, }, //glyph ']' code=60
{ 5,  32,  80, 136,   0,   0,   0, }, //glyph '^' code=61
{ 4,   0,   0,   0,   0, 240,   0, }, //glyph '_' code=62
{ 2, 128,  64,   0,   0,   0,   0, }, //glyph '`' code=63
{ 3,   0, 224,  32, 224, 224,   0, }, //glyph 'a' code=64
{ 3, 128, 224, 160, 160, 224,   0, }, //glyph 'b' code=65
{ 3,   0, 224, 128, 128, 224,   0, }, //glyph 'c' code=66
{ 3,  32, 224, 160, 160, 224,   0, }, //glyph 'd' code=67
{ 3,   0, 224, 224, 128, 224,   0, }, //glyph 'e' code=68
{ 2,  64, 128, 192, 128, 128,   0, }, //glyph 'f' code=69
{ 3,   0, 224, 160, 224,  32, 224, }, //glyph 'g' code=70
{ 3, 128, 224, 160, 160, 160,   0, }, //glyph 'h' code=71
{ 1, 128,   0,   128, 128, 128, 0, }, //glyph 'i' code=72
{ 2,   0, 192,  64,  64,  64, 128, }, //glyph 'j' code=73
{ 3, 128, 160, 192, 160, 160,   0, }, //glyph 'k' code=74
{ 1, 128, 128, 128, 128, 128,   0, }, //glyph 'l' code=75
{ 5,   0, 248, 168, 168, 168,   0, }, //glyph 'm' code=76
{ 3,   0, 224, 160, 160, 160,   0, }, //glyph 'n' code=77
{ 3,   0, 224, 160, 160, 224,   0, }, //glyph 'o' code=78
{ 3,   0, 224, 160, 160, 224, 128, }, //glyph 'p' code=79
{ 3,   0, 224, 160, 160, 224,  32, }, //glyph 'q' code=80
{ 3,   0, 224, 128, 128, 128,   0, }, //glyph 'r' code=81
{ 2,   0, 192, 128,  64, 192,   0, }, //glyph 's' code=82
{ 3,  64, 224,  64,  64,  64,   0, }, //glyph 't' code=83
{ 3,   0, 160, 160, 160, 224,   0, }, //glyph 'u' code=84
{ 3,   0, 160, 160, 160,  64,   0, }, //glyph 'v' code=85
{ 5,   0, 168, 168, 168,  80,   0, }, //glyph 'w' code=86
{ 3,   0, 160,  64, 160, 160,   0, }, //glyph 'x' code=87
{ 3,   0, 160, 160, 224,  32, 224, }, //glyph 'y' code=88
{ 2,   0, 192,  64, 128, 192,   0, }, //glyph 'z' code=89
{ 3,  96,  64, 192,  64,  96,   0, }, //glyph '{' code=90
{ 1, 128, 128, 128, 128, 128,   0, }, //glyph '|' code=91
{ 3, 192,  64,  96,  64, 192,   0, }, //glyph '}' code=92
{ 3,  96, 192,   0,   0,   0,   0, }, //glyph '~' code=93
{ 4,  48,  64, 224,  64, 240,   0, }, //glyph '£' code=94
VGAX vga;
void setup() {
  vga.begin();
  vga.clear(4);
  vga.printPROGMEM((byte*)fnt_ufont_data, FNT_UFONT_SYMBOLS_COUNT, FNT_UFONT_HEIGHT, 3, 1, str0, 10, 10, 1);
void loop() {
Re: Arduino monitor VGA
Pochopitelně - text str0 deklaruješ jako že bude uložený do programové paměti (PROGMEM), tj. Flash, ale d a String(d) máš v RAM, to nejde pro inicializaci něčeho ve Flash použít. Nejjednodušeji to vypiš odděleně, neměnný text pomocí printPROGMEM jak tam máš a String(d) pomocí printSRAM. Anebo ten text nedávej do PROGMEM, to bude trošku plýtvání, ale jestli nebojuješ s využitím paměti, tak to vadit nebude.
morlor
Ahoj dík za odpověď už jsem to vyzkoušel a funguje. Ještě se zeptám má někdo nějaký jiný program pro VGA? Tento program je velký žrout paměti.
IMHO je to otázka rozlišení. 120*60/4=1800
https://github.com/smaffer/vgaxua je černobílá, takže je úspornější, ale zase si zvětšila rozlišení na 192*80, takže 192*80/8=1920 bajtů
Pokud si uděláš vlastní modifikaci, která bude jen černobílá, ale s menším rozlišením - třeba 120*60, tak se ti zmenší spotřeba na 120*60/8=900 bajtů.
Nebo si udělej modifikaci, která bude přeskakovat část obrazu, kde nic není. Něco jako pcx komprese :)
