uart atmega16
jur3c
Re: uart atmega16
Příspěvek od jur3c »
teraz mam trosku iny problem mam kod
Title:    example program for the Interrupt controlled UART library
Author:   Peter Fleury <pfleury@gmx.ch>   http://jump.to/fleury
File:     $Id: test_uart.c,v 1.5 2012/09/14 17:59:08 peter Exp $
Software: AVR-GCC 3.4, AVRlibc 1.4
Hardware: any AVR with built-in UART, tested on AT90S8515 at 4 Mhz
DESCRIPTION:
          This example shows how to use the UART library uart.c
#include <stdlib.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/pgmspace.h>
#include "uart.h"
/* define CPU frequency in Mhz here if not defined in Makefile */
#ifndef F_CPU
#define F_CPU 16000000UL
#endif
/* 9600 baud */
#define UART_BAUD_RATE      9600
int main(void)
{ DDRC=0;
  DDRD=124;
  PORTC=255;
  OCR1A=255;
  OCR1B=255;
  TCCR1A = (1<<COM1A1) | (1<<COM1B1) |(1<<WGM10);
  TCCR1B = (1<<WGM12) | (1<<CS10);
  DDRA=3;
  DDRB=252;
  PORTB=255;
  PORTA=3;
  int a=1;
  int b=1;
  int j=1;
  int d=1;
  int e=1;
  int f=1;
  int g=1;
  int h=1;
  int poz=1;
  int poza=1;
  int pozb=1;
    unsigned int c;
    char buffer[7];
    int  num=134;
     *  Initialize UART library, pass baudrate and AVR cpu clock
     *  with the macro
     *  UART_BAUD_SELECT() (normal speed mode )
     *  or
     *  UART_BAUD_SELECT_DOUBLE_SPEED() ( double speed mode)
    uart_init( UART_BAUD_SELECT(UART_BAUD_RATE,F_CPU) );
     * now enable interrupt, since UART library is interrupt controlled
    sei();
     *  Transmit string to UART
     *  The string is buffered by the uart library in a circular buffer
     *  and one character at a time is transmitted to the UART using interrupts.
     *  uart_puts() blocks if it can not write the whole string to the circular
     *  buffer
    uart_puts("String stored in SRAM\n");
     * Transmit string from program memory to UART
    uart_puts_P("String stored in FLASH\n");
     * Use standard avr-libc functions to convert numbers into string
     * before transmitting via UART
    itoa( num, buffer, 10);   // convert interger into string (decimal format)
    uart_puts(buffer);        // and transmit string to UART
     * Transmit single character to UART
    uart_putc('\r');
    for(;;)
         * Get received character from ringbuffer
         * uart_getc() returns in the lower byte the received character and
         * in the higher byte (bitmask) the last receive error
         * UART_NO_DATA is returned when no data is available.
        c = uart_getc();
        if ( c & UART_NO_DATA )
             * no data available from UART
        else
             * new data available from UART
             * check for Frame or Overrun error
            if ( c & UART_FRAME_ERROR )
                /* Framing Error detected, i.e no stop bit detected */
                uart_puts_P("UART Frame Error: ");
            if ( c & UART_OVERRUN_ERROR )
                 * Overrun, a character already present in the UART UDR register was
                 * not read by the interrupt handler before the next character arrived,
                 * one or more received characters have been dropped
                uart_puts_P("UART Overrun Error: ");
            if ( c & UART_BUFFER_OVERFLOW )
                 * We are not reading the receive buffer fast enough,
                 * one or more received character have been dropped
                uart_puts_P("Buffer overflow error: ");
			switch (c) //Which ASCII character was received?
        case '!':
                    break;
        case 'U':   {PORTD=120;PORTA=1;}
                    break;
        case 'C':   {PORTD=112;PORTA=0;}
                    break;
        case 'D':   {PORTD=116;PORTA=2;}
                    break;
        case 'L':   {PORTD=116;PORTA=1;}
                    break;
        case 'R':   {PORTD=120;PORTA=2;}
                    break;
        case 'a':   {PORTD=112;PORTA=1;}
                    break;
        case 'e':   {PORTD=120;PORTA=0;}
                    break;
		case 'b':   {if (bit_is_clear(PINC,0) && bit_is_clear(PINC,1) && bit_is_clear(PINC,2) && bit_is_clear(PINC,3) && !bit_is_clear(PINC,4) && !bit_is_clear(PINC,5) && !bit_is_clear(PINC,6) && !bit_is_clear(PINC,7))
    {PORTB=0; PORTD=120;PORTA=1;}
   else if (bit_is_clear(PINC,0) && bit_is_clear(PINC,1) && bit_is_clear(PINC,2) && !bit_is_clear(PINC,3) && !bit_is_clear(PINC,4) && !bit_is_clear(PINC,5) && !bit_is_clear(PINC,6) && !bit_is_clear(PINC,7))
   {PORTB=16; PORTD=112;PORTA=1;}
   else if (bit_is_clear(PINC,0) && bit_is_clear(PINC,1) && !bit_is_clear(PINC,2) && !bit_is_clear(PINC,3) && !bit_is_clear(PINC,4) && !bit_is_clear(PINC,5) && !bit_is_clear(PINC,6) && !bit_is_clear(PINC,7))
   else if (bit_is_clear(PINC,0) && !bit_is_clear(PINC,1) && !bit_is_clear(PINC,2) && !bit_is_clear(PINC,3) && !bit_is_clear(PINC,4) && !bit_is_clear(PINC,5) && !bit_is_clear(PINC,6) && !bit_is_clear(PINC,7))
   {PORTB=16; PORTD=116;PORTA=1;}
   else if (!bit_is_clear(PINC,0) && !bit_is_clear(PINC,1) && !bit_is_clear(PINC,2) && !bit_is_clear(PINC,3) && !bit_is_clear(PINC,4) && !bit_is_clear(PINC,5) && !bit_is_clear(PINC,6) && !bit_is_clear(PINC,7))
   else if (bit_is_clear(PINC,0) && bit_is_clear(PINC,1) && bit_is_clear(PINC,2) && bit_is_clear(PINC,3) && bit_is_clear(PINC,4) && !bit_is_clear(PINC,5) && !bit_is_clear(PINC,6) && !bit_is_clear(PINC,7))
   {PORTB=8; PORTD=120;PORTA=0;}
   else if (bit_is_clear(PINC,0) && bit_is_clear(PINC,1) && bit_is_clear(PINC,2) && bit_is_clear(PINC,3) && bit_is_clear(PINC,4) && bit_is_clear(PINC,5) && !bit_is_clear(PINC,6) && !bit_is_clear(PINC,7))
   else if (bit_is_clear(PINC,0) && bit_is_clear(PINC,1) && bit_is_clear(PINC,2) && bit_is_clear(PINC,3) && bit_is_clear(PINC,4) && bit_is_clear(PINC,5) && bit_is_clear(PINC,6) && !bit_is_clear(PINC,7))
   {PORTB=8; PORTD=120;PORTA=2;}
   else if (bit_is_clear(PINC,0) && bit_is_clear(PINC,1) && bit_is_clear(PINC,2) && bit_is_clear(PINC,3) && bit_is_clear(PINC,4) && bit_is_clear(PINC,5) && bit_is_clear(PINC,6) && bit_is_clear(PINC,7))
	else PORTB=24;
	                break;
        case 'c': { PORTD=120;PORTA=1;
   if (!bit_is_clear(PINC,7)) a=1;
   else a=0;
   if (!bit_is_clear(PINC,6)) b=1;
   else b=0;
   if (!bit_is_clear(PINC,5)) j=1;
   else j=0;
   if (!bit_is_clear(PINC,4)) d=1;
   else d=0;
   if (!bit_is_clear(PINC,3)) e=1;
   else e=0;
   if (!bit_is_clear(PINC,2)) f=1;
   else f=0;
   if (!bit_is_clear(PINC,1)) g=1;
   else g=0;
   if (!bit_is_clear(PINC,0)) h=1;
   else h=0;
   poza=(a*0+1000*b+2000*j+3000*d+4000*e+5000*f+6000*g+7000*h);
   pozb=(a+b+j+d+e+f+g+h);
   poz=poza/pozb;
   if (poz==0 || poz<1000)  {OCR1A = 255;  OCR1B = 0;}
   else if (poz==1000 || poz<2000)  {OCR1A = 255;  OCR1B = 200;}
   else if (poz==2000 || poz<3000)  {OCR1A = 255;  OCR1B = 227;}
   else if (poz==3000 || poz<4000)  {OCR1A = 255;  OCR1B = 255;}
   else if (poz==4000 || poz<5000)  {OCR1A = 227;  OCR1B = 255;}
   else if (poz==5000 || poz<6000)  {OCR1A = 200;  OCR1B = 255;}
   else if (poz==6000 || poz<7000 || poz==7)  {OCR1A = 0;  OCR1B = 255;}
	                break;
        case 'd':   {if (bit_is_clear(PINB,0) && bit_is_clear(PINB,1) && bit_is_clear(PIND,7))
     {PORTD=116;PORTA=2;}//dozadu
    else if (bit_is_clear(PINB,0) && !bit_is_clear(PINB,1) && !bit_is_clear(PIND,7))
     {PORTD=120;PORTA=2;}//doprava
	 else if (bit_is_clear(PINB,0) && !bit_is_clear(PINB,1) && bit_is_clear(PIND,7))
     {PORTD=120;PORTA=0;}//mierne doprava
    else if (!bit_is_clear(PINB,0) && bit_is_clear(PINB,1) && !bit_is_clear(PIND,7))
     {PORTD=116;PORTA=1;}//dolava
	 else if (!bit_is_clear(PINB,0) && bit_is_clear(PINB,1) && bit_is_clear(PIND,7))
     {PORTD=112;PORTA=1;}//mierne dolava
    else if (!bit_is_clear(PINB,0) && !bit_is_clear(PINB,1) && bit_is_clear(PIND,7))
     {PORTD=120;PORTA=1;}//dopredu
     else
     {PORTD=112;PORTA=0;}//stoji
                    break;
		default:    {PORTD=112;PORTA=0;}
                    break; //Character unknown to my routine, discard character
             * send received character back
            uart_putc( (unsigned char)c );
a tie programy co mam pod b ,c a d chcem aby robil lenze ja viem ze je to zle pretoze ono mi to urobi len jeden krat cize otazka je ako to spravim aby to slo kym neposlem iny symbol napr. Y
Re: uart atmega16
Příspěvek od Pirx »
Učebnice jazyka C 1.díl 6.v. Herout, Pavel
Napriklad zde:
http://honzaujep.wz.cz/Ucebnice%20jazyk ... Herout.pdf
Nebo si ji kup, coz je lepsi.
jur3c
Re: uart atmega16
no teraz to mam nejak takto ale aj tak ked spustim ten program tak ho nemozem zastavit resp. prepnut na iny
#include <stdlib.h>
#include <avr/io.h>
#include "uart.h"
#ifndef F_CPU
#endif
/* 9600 baud */
int main(void)
{ DDRC=0;
  DDRD=124;
  PORTC=255;
  OCR1A=255;
  OCR1B=255;
  DDRA=3;
  DDRB=252;
  PORTB=255;
  PORTA=3;
  int a=1;
  int b=1;
  int j=1;
  int d=1;
  int e=1;
  int f=1;
  int g=1;
  int h=1;
  int poz=1;
  int poza=1;
  int pozb=1;
    unsigned int c;
    char buffer[7];
    int  num=134;
     *  with the macro
     *  or
    sei();
     *  buffer
    uart_putc('\r');
    for(;;)
        c = uart_getc();
        else
        case '!':
                    break;
                    break;
                    break;
                    break;
                    break;
                    break;
                    break;
                    break;
		case 'b':   do {if (bit_is_clear(PINC,0) && bit_is_clear(PINC,1) && bit_is_clear(PINC,2) && bit_is_clear(PINC,3) && !bit_is_clear(PINC,4) && !bit_is_clear(PINC,5) && !bit_is_clear(PINC,6) && !bit_is_clear(PINC,7))
	else PORTB=24;
	} while(c=='b');
	                break;
        case 'c': do { PORTD=120;PORTA=1;
   else a=0;
   else b=0;
   else j=0;
   else d=0;
   else e=0;
   else f=0;
   else g=0;
   else h=0;
   poz=poza/pozb;
	} while(c=='c');
	                break;
        case 'd':   do {if (bit_is_clear(PINB,0) && bit_is_clear(PINB,1) && bit_is_clear(PIND,7))
     else
    } while(c=='d');
                    break;
Re: uart atmega16
Příspěvek od AlesH »
Problém toho posledního kódu je zřejmě v tom, že např. smyčka s while(c=='b') po zadání 'b' nikdy neskončí, protože proměnná "c" se v té smyčce nemůže změnit.
Předpokládám, že "c = uart_getc();" nečeká na příjem znaku z UARTu, ale i když na UARTu nic není, tak projde dál. V takovém případě je jednou z možností řešení uložit si načtený znak do jiné proměnné, např. "x" (jen v případě, že z UARTu přišel nějaký znak) a v další části hlavní smyčky se pak rozhodovat podle toho "x" pomocí switch(x) nebo třeba if (x=='b') ... else if (x=='c') ... else if (atd.). Pak hlavní smyčka poběží nepřetržitě a akce přiřazená k poslednímu přijatému znaku se bude provádět opakovaně.
Naposledy upravil(a) AlesH dne 28 bře 2013, 20:22, celkem upraveno 1 x.
Re: uart atmega16
Příspěvek od Pirx »
AlesH píše: Předpokládám, že "c = uart_getc();" nečeká na příjem znaku z UARTu, ale i když na UARTu nic není, tak projde dál.
Myslim, ze je to presne tak, protoze "if ( c & UART_NO_DATA )" zjevne testuje vyskyt prijateho znaku.
Snad bych jenom doplnil, ze je vhodne oddelit vykonnou cast kodu od ridici (prikazy z UART) a ve vykonne casti kodu menit jeji chovani podle zmeny stavu, ktery zavisi na prijatem znaku. Vhodna konstrukce pro zacatecnika je treba "switch/case" a nebo lepe konecny automat (FSM).
Re: uart atmega16
Ta knihovna používá přerušení a ukládá znaky do bufferu. Takže je pouze potřeba otestovat jestli v bufferu něco je a pokud ano tak s tím něco provést.
Bohužel ten kód je napsán tak "prasácky", že se v něm nedokážu rychle zorientovat a na hlubší rozbor se mi jaksi nedostává času.
Chtělo by to alespoň nahlédnout do té knížky, která byla doporučena a psát to trochu "normálně".
jur3c
Re: uart atmega16
tak som to teda oddelil aby to nebolo v podmienke prijatia znaku a ide to v pohode diky moc
petr-kubac
Re: uart atmega16
Příspěvek od petr-kubac »
Při vší úctě k autorovi jeho kód je prasárna, před kterou blednou i mé Assemblerové zdrojáky
Příklad
Znamená, že tyto podmínky platí všechy zároveň
PIN C Bit 0 je 0
PIN C Bit 1 je 0
PIN C Bit 2 je 0
PIN C Bit 3 je 0
PIN C Bit 4 není 0 - tedy je 1
PIN C Bit 5 není 0 - tedy je 1
PIN C Bit 6 není 0 - tedy je 1
PIN C Bit 7 není 0 - tedy je 1
Takže bych řekl že celá ta prasáckost se dá napsat jako
if ( PINC == 0b11110000 )
A když to vezmeme řádek po řádce tak můžeme klidně pokračovat ve stejném stylu.
Dokonce bych řekl, že napsat to tak jak to má autor je výrazně pracnější než napsat to správně
nebo jsem se spletl ?
jur3c
Re: uart atmega16
určite to je prasarna ale to boli prvé programy kde som veľa prepisoval :D som to nechával v takom tvare ale to sa este veľa krat prepise
Re: uart atmega16
Ale kdepak to není "přepisováním" to je tím, že napsat nějaký kód, který jde přeložit, neznamená, že umíš programovat.
Pochop, že slušně napsaný kód je hrozně užitečný když je třeba potřeba najít chybu.
Komentáře tam máš prakticky jen ty co už jsou v tom příkladu ze kterého jsi vyšel. Každý začátečník na tuhle poznámku odpoví, že to má teprve rozepsaný a komentáře dopíše až to bude hotový. Tak to je taky chyba. Měl by jsi si přečíst trochu teorie. Možná pak zjistíš, že to všechno nejsou jenom "kecy" ale že to opravdu funguje.
Mimochodem Petr si narozdíl ode mne našel čas přepsat tu tvou "mega-turbo-podmínku" do normálního tvaru, kde je mi hned jasné o co jde.
Myslíme to s tebou dobře tak si nech poradit :)
