Jindro, zkousim udelat neco podobneho, dnes mi prislo toto
https://www.aliexpress.com/item/M10-5-8 ... 225f3ac2b9 vnejsi prumer unasece je 16mm
https://www.aliexpress.com/item/Newest- ... 4c4dtGbdAA
ale mam to na rezani plastu (z ABS krytu od tiskaren si chci delit "montazni desticky")
na laminat to bude chtit nejaky kvalitni kotoucek.
upinaci stopka piloveho kotouce na vrtacku
https://www.aliexpress.com/store/produc ... 474cJN8KKS
Naposledy upravil(a) Vladimir66 dne 16 lis 2018, 21:46, celkem upraveno 3 x.
XH konektory (jsou treba na nekterych NEMA23)
https://www.aliexpress.com/item/10Sets- ... 4c4dVlpqGi
upinac klestin ER11,ER16,ER20 (kvalita??)
https://www.aliexpress.com/item/ER11-Co ... f912b5d4fd
https://www.aliexpress.com/item/C20-ER1 ... a59aZ2NBv9
https://www.aliexpress.com/item/C25-ER2 ... a59aBCnuGh
lozisko v domku
https://www.aliexpress.com/item/KFL08-K ... 3c00fV96yW
remenice GT2
https://www.aliexpress.com/store/produc ... 7f72KI4Rcf
ceny malych oled pomalu ale jiste padaji
https://www.aliexpress.com/store/produc ... c813ZQEHyl
vibracni senzor
https://www.aliexpress.com/store/produc ... 120beyjltc
prototype PCB 10x10 (ctvercove se spatne shaneji)
https://www.aliexpress.com/item/10x10cm ... 3c00CPcM0o
EEPROM programmer
https://www.aliexpress.com/item/Origina ... 974fd7a54e
Arduino UNO je stejne drahe jako Nano ..
https://www.aliexpress.com/store/produc ... 6978IijwWN
USB-SATA kablik pro HDD (od 2ks shipping!)
https://www.aliexpress.com/item/22-Pin- ... cb577b9b16
remenice GT2
vibracni senzor
EEPROM programmer
IEC320 konektory - popis: https://www.stayonline.com/product-reso ... iec320.asp
IEC320 ruzne redukce
https://www.aliexpress.com/store/produc ... 71830IJSWv
https://www.aliexpress.com/store/produc ... 4988QYWjhk
https://www.aliexpress.com/item/Univers ... 95342.html
drzacky na kabely
https://www.aliexpress.com/store/produc ... 3d6dQxkklW
https://www.aliexpress.com/store/produc ... 5167NJhcSn
"Duplo" kostky
https://www.aliexpress.com/store/produc ... 7ec3FFsuBr
neodymove magnety
https://imagnet.aliexpress.com/store/37 ... 4cdfQv6Gk2
vrtak za kacku
https://www.aliexpress.com/item/50Pcs-H ... d682aeffd5
https://www.aliexpress.com/item/2016-NE ... 9758c312a6
neopixely
https://www.aliexpress.com/item/1pcs-Ne ... 4c4dCJBpoa
https://de.aliexpress.com/item/RGB-LED- ... 1d6b07e1-5
https://de.aliexpress.com/store/product ... fe69Tpua8Y
gas senzory (MQ-moduly)
https://de.aliexpress.com/store/group/M ... 7fb9I9WWhD
kleste na sundavani buzirky LB1 (snad lepsi nez FS-D3)
https://www.aliexpress.com/item/Adjusta ... 3c00ouOhJG
drzacky na kabely
"Duplo" kostky
neodymove magnety
vrtak za kacku
neopixely
Da se u tech klesti nastavit tloustka kabelu (a jak), nebo to je jen "s citem stiskneme a zatahneme a snad neprestrihneme"?
ad kleste - az prijdou, vyzkousime ..
bezdratove nabijeni (Transmitter Receiver)
https://www.aliexpress.com/store/produc ... 6b2fmWzpeY
male PIR
https://www.aliexpress.com/store/produc ... 7c31AeRMJf
https://www.aliexpress.com/store/produc ... 359aNKT56B
plastovy pasovy podvozek
https://www.aliexpress.com/item/Brand-D ... 12115776f7
charger shield (2x aku16340)
https://www.aliexpress.com/item/ESP8266 ... 9a974c8aee
l293 modul driver
https://www.aliexpress.com/store/produc ... 2625LNPxXs
l293 E12 Lua driver
https://www.aliexpress.com/item/Motor-S ... b4ddeac546
https://www.aliexpress.com/item/ESP8266 ... 465e5fabda
"l298" dc driver (standby 0.1uA)
https://www.aliexpress.com/store/produc ... 25836xO5Kt
USB to LPT redukce
https://www.aliexpress.com/store/produc ... 19fcaZX5hH
SD to CF redukce
https://www.aliexpress.com/store/produc ... 581f2iTxJO
nabijeci modul 18650 3S z aku-sroubovaku
https://www.aliexpress.com/store/produc ... 996aP71Esg
napajeci redukce Lenovo
https://www.aliexpress.com/store/produc ... 2b25a3rqPY
https://www.aliexpress.com/item/5-5-2-5 ... a45495792c
nadobka na flux + nastavce
https://www.aliexpress.com/item/50ml-Em ... ab0465dfdf
DS3231 real clock (dutinkovy konektor)
https://www.aliexpress.com/store/produc ... 39beLqvGc9
male PIR
l293 modul driver
l293 E12 Lua driver
USB to LPT redukce
SD to CF redukce
Naposledy upravil(a) Vladimir66 dne 11 pro 2018, 18:22, celkem upraveno 1 x.
Pokud jde o pásové podvozky (ale mají tam i jiné věci), tak zajímavý je tento obchod.
Mají tam i jednotlivé díly jako unašeče, pojezdová kola atd.
Mám tam něco objednáno, tak až to dorazí, donesu ukázat Odhadem na lednové RoboDoupě.
a zase zarovky..
PIR zarovka
https://www.aliexpress.com/item/LED-PIR ... 3fa22a3352
https://www.aliexpress.com/item/IP42-LE ... fc31b3308e
kamera v zarovce
https://www.aliexpress.com/item/KERUI-L ... f25dc17478
https://www.aliexpress.com/item/960P-10 ... 8fb67d97a4
a se zvukovym senzorem (nocni rezim)
https://www.aliexpress.com/item/Smart-S ... 79dafd167b
sviti jen v noci
https://www.aliexpress.com/item/E27-Led ... 79dafd167b
a par dekorativnich zarovek
https://deng.aliexpress.com/store/group ... 2391NifGdu
vodotesna krytka na packovy vypinac
https://www.aliexpress.com/store/produc ... 6fe6s8c8aX
motory N20
https://www.aliexpress.com/item/Free-Sh ... 71b9d53cfa
PIR zarovka
kamera v zarovce
sviti jen v noci
motory N20
Pár lidí zaujaly moje nabíječky (nejen) na Lipol LiitoKala, bluetoooh sluchátka a "převaděč" audiosignálu z 3,5 jacka na bluetooh. Jelikož jsem to sem dával, tam to opakuji výřezem ze svého vcelku rozsáhlého příspěvku:
POZOR: Nabíječky jdou koupit občas výhodněji třeba na eBay či Ali nebo i jinde. Ne všechny ale fungují i jako powerbanky. Pokud o tuto funkci stojíte, zkontrolujte, zda tuto funkci podporuje!
Jak jsem se díval, tak prakticky vše podražilo. Navíc jsem to tenkrát kupoval ve slevě. Byly to věci na které jsem nespěchal.od kolbaba71 » 14 říj 2018, 21:17
Jednoduchá nabíječka na 18650 co jde použít i jako powerbanka (existuje verze i bez funkce powerbanky)
Odkaz pro 1 šachtu, 2 šachty či 4 šachty
Bluetooh slucháka (Relativně nedávno nabízené na nějakém slevovém portálu ve "slevě" z 1800 na 690Kč)
odkaz
Bluetooh pro dvě zařízení. Zdroj signálu je 3,5 stereojack
odkaz
Al spojky (shaft coupler)
https://www.aliexpress.com/item/Ship-di ... aaded05d12
barevne butonky pro tlacitka
https://www.aliexpress.com/store/produc ... 3f2bjiam9n
neopixely
https://www.aliexpress.com/item/DC5V-WS ... 4c4deIGGpu
ctecka v nabijecim kabelu (iPhone)
https://www.aliexpress.com/item/Dr-Memo ... &tpp=1
ctecka SD, microSD (USB, iPhone)
https://www.aliexpress.com/item/3-in-1- ... 1ba6J4uQpk
sada napajecich konektorů
https://www.aliexpress.com/item/56pcs-U ... 45a43599cd
neopixely
